wierd vibertion help?!?!?
YukonJonny
I have a 2004 GMC Yukon Denali, it recently started viberating around 15-60 mph I just put on new tires had no issues before. I thought it was the u-joints and replaced them still there, I have replace front and rear diff. fluid and also the transfor case fluid. I cant seem to track it down and I need help asap thanks
imi4tth3w
Texas
definitely have the tires rebalanced. they might have not balanced them right. if it wasn't happening before tires and now it is after tires, thats probably your issue.
what tires did you have installed and where?
Y
YukonJonny
@matt thank I know its not the tires it is more of a fine vibration not like an out of bal. or out of round tire, felt like u joint and I replaced them. still vibrates no shake.
I have 305/40R22 toyo st2 I installed them at Les Schwab tires. I used to work there so know the guys there I also rotated the tires and the vibration stay in the rear I feel it in the seat only when driving accl and deccl.
So your truck was fine no vibration no issues at all then after you replaced the tires it started acting up?
Sounds like maybe one of your tires isnt isntalled correctly?
Either not sealed correctly or not balanced?
I would bring the truck back to the place that swapped the tires out for you and tell them about the issue.
They should be more then willing to assist you at no charge to you since it wasnt having the issue prior to you bringing it to get worked on there.
I would do it asap though..
Because the longer you wait the more chances it has to mess the tires or something else up..
HeavyHoe03
