Danny_Z56
This started happening two weeks ago.
It started off when i went to go somewere and all i got was rappid clicking and no rollover.So i jumped the battery with the wifes car.After jumping my Tahoe it fired right up.Drove it with out issue for like two days.Then the same BS happened,again jumped and fired up.However now if it sits overnight the battery is pretty much dead.
So then i swap out the battey with one my brother gave to me a while ago.The motor turned right over.However i ended up getting the same BS even with the swapped battery.
So i talked to a few guys and both told me i need a new alternator.So i went and got a bran new alternator and installed it.I charged the battery and it fired up.Let it run for a while to make sure the battery got good and charged.I then shut off the motor and started it back up,it did so just fine.
Then for a test i turned on my vehicle stereo and let it play a CD for around 20-25 minuts.Normally i can play a CD with motor off for hours.Well in that short amount of time playing the CD my vehicle would not start....
So now im at a loss,i don't know what could have chaned in the last few weeks that could have caused this.Normally the motor fires right up each and every time,never had an issue.
