what would it take to install a lt4 hot cam?
felskee
what would it take to install a lt4 hot cam? parts? prices? i have a 99 tahoe 5.7
---------- Post added at 01:25 PM ---------- Previous post was at 01:23 PM ----------
or any other type of cam
retorq
Kingman AZ
Have you ever swapped a cam before?? It's basically that ... Ohh and a tune. And if you don't already have it a good free flowing exhaust and intake.
LT4 Hot cam is probably too big for a big 4 door, the operating RPMS may be a lil high for you.
It lists .525 lift with 1.6 rockers, you WILL need to check your clearances, Vortec heads need work to get lift that high. I bet you will need upgraded valve springs too ...
felskee
felskee
then what would an alturnitve choice cam wize? i would want one with less work in volved. i know swapping a cam isnt all that hard.
retorq
Kingman AZ
Have you swapped a cam in the vehicle before?? Have you swapped a cam in a Gen 1 engine before??
97yukon
baton rouge
get on fullsizechevy, performance trucks. guys doing lt4 hot cam all day long no problems. tells you exactly what there doing. springs, retainers and all the other goodies you need. how much it cost them and the works. from what i understand through many sources, its the biggest you can run without machining heads and all that good stuff. i put up the zz4 option on performance trucks and basically was laughed at. i feel like performance trucks typically has a more educated opinion imo. nothing against anyone on the this site...i obviously like this site as well. put if you want alot of info...check those two sites out.
steamroller
The South
get on fullsizechevy, performance trucks. guys doing lt4 hot cam all day long no problems. i put up the zz4 option on performance trucks and basically was laughed at.
Where are all the 1/4 mile times with these hotcam equipped trucks? All I ever see is idle videos and that's useless as far as performance is concerned. You got laughed at because they're all a bunch of LS leghumpers over there
losloho02
