What is this?
h22dx
What is behind this panel? When I start my car it sounds like a motor priming for about 5 seconds behind it?? 20170226_162039.jpg
HiHoeSilver
Away!
Chicago
I actually do think there is rear heat actuators in there... Not positive though.
06 Yukon XL
Depending on year rear A/C maybe I there. It was okay my 2006 xl
HiHoeSilver
Away!
Chicago
That's a possibility but it comes on everytime you start it, even with all the hvac off.
Yeah, I think those actuators calibrate and find their spot. Its a little servo motor, if it's going bad it will keep searching. Does your rear ac work?
H
h22dx
The rear works great when it works, a lot colder than the front. However I have a leak somewhere and a charge only last about 2 weeks
HiHoeSilver
Away!
Chicago
Does the noise happen when you turn the key to on without starting? Maybe you are just hearing the fuel pump.
HiHoeSilver
Away!
Chicago
Good point, yes it does
The fuel pump is in the tank, but is audible for sure. I guess something hvac related may come on with just acc power, too, but I forgot no rear heat on OBS, so why would there be an actuator back there? I'm betting @Tonyrodz is right.
:waytogo:
Is the obs fuel tank in that area? I know the nbs fuel tank is on the driver side between front seats and 2nd rows, or there abouts.
fishmagnet
Rear AC blower motor in there, fuel pump on the other side underneath and inside fuel tank.
Big Mama
Virginia
Do you have auto ride? Could be your compressor turning on to level the ride.
JPeter
