What is this? (ceiling of my Denali)
mharders
Just outside of Seattle
I believe that pic is of the climate sensor. Try blowing it out with compressed air (can) or gently with a air compressor. I had the same issue and this worked for me.
mattah
Austin, TX/Temple, Tx
I think it works in pair with your onstar. and bluetooth
When you use onstar and have the rear ac on blast it will turn the rear ac down so the person on the other end can hear you.
Regency
It's detecting the temp so when you remote start or out it on auto it blows correctly it was going off every morning for a while like 2-3 years back but my mom just gave it a good hit and it works like a brreeze now
NathanJax
Vacation Nathan
Jax, Fl
Aspirator fan for the auto A/C...
It's dirty. You can take it apart and clean it or get a new one.
Subject: Buzz Noise From Headliner Above Driver - keywords ac air aspirator cover fan grille HVAC interior microphone sensor speaker temperature vent vibration
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in the PI.
Condition/Concern:
Dealer or customer may comment that they have a buzz or vibration noise emanating from the headliner in an area that looks like microphone or a speaker.
Recommendation/Instructions:
The plastic escutcheon grill, which is round and about the size of a half dollar and located just above the driver to the left, is the interior ambient temperature sensor. The sensor is used in conjunction with the automatic HVAC (C68). On occasions, this sensor has been known to make a buzz or rattle sound. The sensor uses a small fan to pull air over the sensor. This buzz noise may be intermittent.
Although it may not be possible to alleviate all of the buzz or noise from this sensor, Engineering has found that if the sensor is installed incorrectly that it may bind and cause the fan to make a buzz noise. Remove the sensor and while doing so check for any binding. Reinstall the sensor and re-test. If the noise is still present, the sensor itself may be noisy and require replacement.
NathanJax
Vacation Nathan
Jax, Fl
How do you get to the sensor? Does the cover unscrew or pop off?
go through the top of the headliner. it does come off, but usually people break it. if you get to it from the top, by just pulling the liner down, you'll see how it twist off
Candielaine
