What in-car gauge is most important to monitor?
  • Wideband Air/Fuel ratio
    Votes: 3 14.3%
  • Boost
    Votes: 3 14.3%
  • oil pressure
    Votes: 10 47.6%
  • EGTS
    Votes: 0 0.0%
  • volt
    Votes: 1 4.8%
  • fuel
    Votes: 8 38.1%
  • water
    Votes: 3 14.3%
  • Gas
    Votes: 2 9.5%
  • tranny temp
    Votes: 6 28.6%
  • Vacuum
    Votes: 0 0.0%
  • Total voters
    21
JennaBear
Resident Ninja
San Diego, CA
Depends on your mods really. I would go with trans temp 100% as these 60e transmissions have some issues from the factory. If you have a blower, then most definitely a wideband and boost gauge.
JennaBear
Resident Ninja
San Diego, CA
I am running a PLX DM-100 and an Autometer Interceptor. I have access to virtually everything without hooking up to EFILive, I am real happy with both of them.
nc6600
ps trucks in drive
Cary/Apex NC
I like to watch my gas gauge, because i don't want to have to push this heavy ass thing.
A
AtomicHoe094
Atomichoe094
cleveland, OH
smart ass lol
---------- Post added at 12:12 AM ---------- Previous post was at 12:11 AM ----------
any more info on one of those :) thanks
JKmotorsports
Austin, TX
I mainly keep an eye on my AFR and eng temp. I glance often at the oil pressure and boost gauge also. And if I lay into it hard and play around, I have to watch the fuel gauge more often:)
I'm going to install an Aeroforce Interceptor so I can keep track of my IATs, oil temp, trans temp, and a lot more.
JKmotorsports
Austin, TX
Damn man, sorry. You missed it by one year. I forgot your truck was a 95. Well, if I were you, I'd add a trans temp gauge, wideband, and make sure you have an accurate oil pressure gauge, especially if you're still running the original pump. Without oil pressure, you can forget about having to monitor anything else. You'll have other things to worry about if you lose oil pressure while running your engine.
A
AtomicHoe094
Atomichoe094
cleveland, OH
hahaha no no its fine.. So if i get a trans temp gauge, What numbers should i be watching out for? What is "hot"?
A
AtomicHoe094
Atomichoe094
cleveland, OH
It is already in my stock gauge cluster, so I wouldn't consider buying another one!
+1.. i mean i think my 97 yr old grandpa could give the advise to look at a gas gauge. And im sure everyone can state the obvious, cant go anywhere without gas.
TahoeGoBoom
blue interior guy
a bunch of the options are the same..
gas/fuel,
boost/vacuum.
just sayin.
and in my truck, i like oil pressure, engine temp, and gas.
but it all depends on the car.
tbh, i keep an eye on most of em. theyre there for a reason. its just what you need to add.
thumper_ehhhhh
Canada ehhhhh
I tow alot so tranny guage is very important. I had a autometer one in my astro but im leaning towards a aeroforce one. My buddy has a different one i'm also looking at it's all digital more compact than the areoforce one. If I remember next time I see him I will get the name of it.
Ok I found in in another thread it's a dashhawk Same idea as the aeroforce one but seems to show more things on the muilti level screen. I like the limits setting option you can use to warn you of getting close to your set limits. He recomends it. This is more than likely the route i'm going to go.
wwiizz
