Wet carpet rr footwell- stopped up rear A/C drain
OneofFew
Talullah Falls, Ga
If you have not made it a routing to check and unclog the rear a/c condensate drain, now is a good time. It is located at the rr corner of the vehicle about the exhaust tip. Look for the a/c hoses entering the cabin, look just infront of them for a black nipple and manipulate it. you can use various tools to gently go into it and root around.
Teamiez
Mine never drips nor does my carpet get wet which is weird...however when running and in that drain area by the lines & exhaust is it normal to feel air while running?
Teamiez
Most condensate drains will vent air out.
Figured it was normal, if it was a refrigerant leak or something along those lines I think my ac would have stopped working a long time ago!
Jjuarez2
What years is that on my 2021 Yukon gets wet in 3rd and 2nd row
MrLeritz
