hiwaycruzer
Hello fellow Tahoe/Yukon owners. I hope someone has experienced the problem I'm having and can point me in the right direction. During a heavy rain, my '96 Tahoe (4x4 4-door with barn doors) has water leaking into the right rear cargo area, getting the carpet and padding wet. I pulled the cover from the tool/jack compartment and found a pool of water and rusted sheet metal directly below the jack mount. I was wondering if there is a known concern with the rear side window gaskets leaking. The rubber seals around the barn doors look OK as do the seals under the roof rack mounts. Before I make an appointment with the Glass Doctor or a body shop, I'd greatly appreciate any information regarding this issue. Thank you all!
