Water in park/turn signals no light
4myfreedom
Washington, DC
Discovered water in park/ turn light lenses removed water got new bulbs but no lights now ? Advice needed checked relays turn and turn fuse in block
that's a pretty common problem, best to just buy new housings, clean up the metal contacts on the connectors, and drive away happy.
the only other thing it could be is a fuse.
depo makes some decent aftermarket oem replica housings, you can find them on rockauto, amazon, ebay, etc..
4myfreedom
4myfreedom
Washington, DC
Yeah buildup and a fuse where do I get bushing that go around the socket ?
the dealer sells a replacement socket with a wire lead and it will come with a rubber seal, just use the seal from that, you can probably find it cheaper online.
sometimes the housings start to leak and not necessarily from the seal area which is why I recommend just replacing the housing once they start to leak.
RED TAHOE LS
Rossville, Georgia USA
Times two on previous post by Wes. If your leak looks like moisture, simply drill a really small hole to the side and lowest part of the lens, it works.
David g...........:)
4myfreedom
4myfreedom
Washington, DC
Do you have link to some
griffey_mojo
