Walk around after cam and heads
JDopirak
I did a short walk around of my yukon after heads/cam swap. Untuned
You can barely hear the cam im considering installing a electric cut out for when i dont have the family and i wanna hear the lope.
Tsp 212/218 113lsa
Prc cnc ported 243 heads (It came with 799s stock but didnt want alot of down time so i bought 243/799 heads and sent them out ahead of time)
10296 melling pump
Upgraded trunuions
Tsp 7.4 hardened pushrods
Gibson ceramic headers
Ls6 springs
Ls7 lifters
Dod delete
Ls3 tb
S@b intake
4port steam port.
Aluminum oil barbell
Magnaflow muffler
Slp resonator delete
Monz11
Da Burg, Fl
NICE! I recently bought a similar Cam package w/ DOD & VVT delete kit, from Texas Speed
TSP0813TKH TSP 2007.5-2013 GM Truck/SUV, 2WD & 4WD 1-3/4" Stainless Steel Long Tube Headers w/ ARP Hex-Head Bolts
(@powder coater now)!!
122-MEL10355 Melling High Volume/High Pressure Oil Pump
25-VVTDelete VVT Delete Kit
25-DODdeleteKit DOD / AFM Delete Kit for 5.3/6.0/6.2 Engines
  • Vehicle: Chevrolet - Tahoe - 2012
  • Morel LS Drop In Lifters (328-6504)
  • Mahle MLS 5.3/5.7 Gasket #168-54442 x2
  • ARP Head Bolts #46-134-3610
  • Include L92 Valley Cover w/o PCV Provision #28-12598832 (Truck/G8 Applications)
  • ARP Crank Bolt #46-234-2503
326-07-07-07 Circle D Specialties High Perfromance GM 6L80 LS Torque Converter, 2600-2800 RPM 1A
25-CamPkg1 Texas Speed Beehive Spring Cam Package for Cathedral Port Heads (LS1/LS2/LS6)
  • Stage 2 5.3 Truck Cam 212/218, .600"/.600" (112 LSA)
  • Standard 5150 Cam Core
  • PAC 1219 Single Beehive Springs (For Cams Under 230 Duration) #97-PAC-1219
  • Please Include Seals (150-900FK x8 & 150-901FK x8)
  • 7.400"
  • GM OEM LS2 Timing Chain Set - 4x Cam Gear
  • Include Crank Bolt/Gasket Kit w/ ARP Bolt #28-CamGskKitARP
JDopirak
JDopirak
  • 7.400"
Im very curious to hear what your oil pressure is at after the install. I am currently considering changing the oil pump to a m295 or 10295 because im at 37-40psi warm idle and 82psi reving it at 4k in park. I haven't taken it past that due to not having a tune. I currently have the 10296 but i installed new cam bearings so i think that with a brand new cam really shot my oil psi up.
ls1frc
Sounds good. 5.3 or 6.2?
I just got done doing a similar build on my 5.3, except I opted for the BTR stage 1 truck cam. I was just going to do DOD delete and put the same heads back on, but like you didn't want any downtime, so I bought the same heads outright from TSP (no core). After I took them off, I saw how oil fouled they were and was glad to have a clean set on hand.
It really woke my 140k 5.3 up, it's actually not anemic now and pushes you back in the seat very nicely. I just wanted some decent passing power and to be able to get going easier at part throttle. It definitely succeeded there.
The one disappointment was how much louder the valvetrain is now. I wasn't suspecting a low lift cam to be this noisy but I guess it comes with the territory of faster ramps on the lobes.
FYI I have the melling 10295 pump. It has 5 psi or so over stock. That's the one you want after disabling DOD since you don't need the higher volume now for AFM to work properly.
09_4WD_YUKON
I've noticed that lower LSAs tend to have more of a noticeable lope. Is this true? I tried reading what exactly LSA is but never saw anything that tied it the sound of the lope. You can hear a small lope in it....maybe a tune will bring it out more. Has it been tuned yet?
kbuskill
NE. FL.
LSA = Lobe Separation Angle
This is the number of degrees between the peaks of the intake and exhaust lobes on the cam. The lower the LSA (lobes closer together) the more overlap the cam has and the more lope you will have. This also creates less low end torque because it bleeds off some of the compression.
09_4WD_YUKON
Thank you Ken!
JDopirak
JDopirak
Welp i dropped yukon off at tuner on Friday.
What's everyone's guess??
Previous was 268whp 289tq.
Im guessing 310whp and 322tq.
JDopirak
JDopirak
Just picked my truck up from the tuners!! Excited to put some miles on.
330whp 325tq
09_4WD_YUKON
Nice!! Did it change the sound of the exahust any? Post another video, please.
JDopirak
JDopirak
Wow, what a difference a tune can do versus just replacing parts. Nice.
Well im not sure what the baseline was with cam and heads. The 268hp-289tq was what it was dynoed at a year ago when i had them tune it. But a year ago the stock tune baseline was 246whp amd 281tq so a tune gained 22hp and 8tq.
ls1frc
It's like night and day isn't it?
It's borderline undrivable in stock form on the 5.3. No power at all.
JDopirak
JDopirak
Welp that didn't last long, This is what was in the drip pan after i did a 100 mile oil change...... Did oil change after fire up and it ran for 30 min or so. So this was second oil change since fire up with new cam, cam bearings and heads...... I did some no no's when putting it back together and im paying for it. Soooo i guess ill start saving for a 6.0 and swap heads over to that after it gets rebuilt.
6point2lovelifers
