Voltage question
rockymt21
wing addict
from the slums of shaolin
So here is a little preface,
About 2 weeks ago the truck wouldn't start, took it to the garage and it turns out my fuel pump went. So I had that fixed, truck drove fine for a couple weeks.
Then on Saturday my truck almost died when I was getting gas, it was running but all the dash lights went out and it was on the verge of dying. I drove home and the battery died completely right in front of my house. I jumped the truck and it started and ran until i took the cables off the battery.
So I went out and bought a new battery, Die Hard Gold from Sears. Pop it in and it works like a charm The Gauge measured between 14 and 16 volts that night. Today I noticed the dash lights weren't as bright as they were the other day, sure enough the voltage gauge measured 10.
Should I have it looked at or is 10 an acceptable number?
The only electronics running are my Alpine head unit and iPod.
MikeTheApeman
The armpit of America - New Joisey
Just my opinion here, but the question is not whether 10 is an acceptable number. the real question is why did the battery go from 14-16 all the way down to 10 is (best I can gather) a week or so?
Sounds to me like your alternator might be on its way out. It might be providing some kind of charge, but not enough to keep the battery where it should be. Might want to swing by Autozone and have them check it for you under load.
rockymt21
rockymt21
wing addict
If the alternator is the issue,
Should I not drive the vehicle or am I okay to drive to tonight and part of tomorrow before I can get it checked out? In other words, is it going to die on me randomly?
Max
Mile High
Denver
You're gonna scoop a bigger stereo at some point, correct? Seems time to upgrade into a bigger alty they 145 amp esky units are quite common at salvage yards or you can check the local alternator shops sometimes they rewind them and have a few cores laying around for cheap.
VA
Headlights make the battery drain quicker if its the alternator, I wouldn't recommend driving it. It will could die on you while driving. It has happen to me years ago. Your truck will lose power while driving, until unable to move and will shut down. This could leave stranded on side the road or in the middle of street! Best to leave it park until able to get it to a shop
Max
Mile High
Denver
Easy stuff dude right on top of the motor you just need a basic set of hand tools.
---------- Post added at 03:51 PM ---------- Previous post was at 03:50 PM ----------
Check the salvage yards first...seriously they're better and cheaper at least buy the 145amp for a denali/escalade if you get one at a parts store.
rockymt21
rockymt21
wing addict
Ouch, $189.99.....Maybe I will check into the guy on GMFS. In regard to local junkyards, is the 145 amp alternator only found in Denali's and Esky's?
Also, the 145 amp is the 5 3/4" size right? The guy on the phone mentioned there being two sizes.
blueflamed03
Oklahoma
yep, alternator. You were high voltage and lights worked good, off the battery until it ran out of charge (alt)
rockymt21
rockymt21
wing addict
Well I just ordered a 145amp alternator from Advanced Auto parts. Ended up being about $170 but it will be here at 7:30 tomorrow morning and I really need my truck for school.
rockymt21
rockymt21
wing addict
I am having trouble removing the alternator,
I have the two bolts, the wire harness and serpentine belt. I don't see anything else that needs to be removed, all I can see is two "compression ring" type things where you insert the bolts. Do these need to be removed? How would I do that?
I need help pretty quick so thanks in advance.
MikeTheApeman
All this talk about 145amp Alternators got me looking at my RPO's, was there a 160amp alternator available on these trucks?? I have an RPO "KW1 - Generator 160 AMP" on my list.
Reason I ask this here is if there was such an option, and he's looking to install a 145 in place of a 160....just askin, not trying to cause trouble here.
EDIT: Just saw in 2005 they bumper the factory alt from 145 for 160. Just an FYI.
And glad you got the alt installed, rocky.
badtothe bone
western pennsylvania
I'm sitting here reading this post, wondering where it will all go.
I am a real fan of 1970's technology. But I have to tell my dad all the time, that it is not 1955 anymore and there is no points, plugs and condenser for a tune up. Everything today is ran by computer.
The SI series of alternator is no more and there is no voltage regulator to adjust and so just swapping out a alternator or a battery when the computer could be at fault - isn't always the solution.
It doesn't matter how big the alternator is or how many batteries you carry, if the computer doesn't tell it to turn on until there is a demand or if the computers doesn't shut off stuff when you turn the key off, there is where you will have your drain.
The radio in your new vehicle is connected to the body control module and the power train control module.
Just asking a simple question like why is my battery going dead, just isn't going to get it in todays world. These new vehicles are not that simple.
When you said about your Alpine Head Unit, a bright light appeared overhead and a loud ahah came to mind. Now it is all coming back to me.
Unless you have a converter unit that takes the place of the stock head unit, or unless you moved the head unit to a different part of the vehicle, you are going to continue to have problems. In some cases, the vehicle will not even start because of the theft lock - where the radio must be in the car for the car to run. Other times, the computer does not shut off a module - lets use a module on the transmission for a example.
Since your transmission is shift by wire, because there is not any linkage going from the shifter on the column to the transmission, it also has sensors on the shift motor which tells the vehicle which gear it is in and to turn on the back up lights when it is in reverse and also to unlock the doors when you put it in park and to lock the doors - say when it gets up to 15 mph.
A acceptable amount of error on the program that runs the computer was 1 line of error for every 10 lines of code. Even the updates were sometimes worse then the origional programs. So there you were, you bought a new vehicle and you were all fat, dumb and happy. One day you stopped at a railroad crossing and you turned off the engine - to save gasoline, and you listened to the radio for 15 minutes while the train went by. Only when you went to start your vehicle, the battery was dead.
Ok - so your first thought is that the battery must be at fault, so you run right out and you buy the biggest battery that they make.
Six months later, you are at the same railroad crossing and you do the same thing and again the battery goes dead. So you figure - well the alternator must be at fault. So you run right out and you buy the biggest alternator you can find. Another six months goes by and this time you go to the mall to get a few things and when you come out into the parking lot, the battery is dead. So you figure - it must be the battery, so you go out and you buy a isolator kit and two Optima batteries. Problem solved right?
Well two weeks goes by and you go out in the morning to start your truck to go to work and now the four wheel drive lights are all lit, and the service four wheel drive is lit in the DIC.
So you start yanking wires and you drive down to the dealership and you hand them the keys and you demand that they sell you a new truck because this one is a lemon. You put thousands of dollars in it and a whole bunch of time into it and you can't keep the battery charged and you are tired of screwing with it. So you give him $30,000 and your old truck and you drive away in a new truck, maybe even a different brand - manufacturer.
The next day, the Chevy garage pulls the truck into their service bay and they hook up the Tech II and they scan the program and they see the errors and they download a new program into the computer and they take out the big batteries and junk that you wasted your money on and they sell the truck out on their lot for twice what they gave you on the trade.
1970's technology - you throw parts at it until it works.
2000's technology - you take it to a dealer and they change the computer program and the truck runs. Which is better?
ecordell
CordellDesigns.com
Merica
Exactly!
Go ahead and take yours to the dealership, let them hook your shit up to the computer, download the new program and whatever else they decide to do, and then when you get the bill, scan it and post it here and we'll compare your receipt with rocky's receipt and see who got screwed in the end.......
Sometimes it's not about taking the easy way out ;), some people like to work on their own vehichles and as a last resort, let the stealership look at it.
blueflamed03
Oklahoma
I read a voltmeter, if it's not charging, I change alt, if it doesn't keep the charge, I change the battery. Worked for me for 42 years, on an array of cars.
