Voltage meter
M
mo2058130
The more and more this goes on. The more I think it is a bad cluster.
GM Guage Specialists damaged my original cluster while adding trans gauge and so he sent me this afterward. It’s got other issues and I’m thinking this is another one.
2005 GMC Yukon XL
Larryjb
I'd be more interested in what your volt meter says, not what the dash gauge says.
Also, your first picture with key on/engine off, your door was open so the interior lights were one. This will drop the voltage a little too.
From your post #12, you had a voltage of 13.5V with the engine running /AC on. This voltage should have been higher. Brad (post #25) may be correct. Get yourself a rebuild kit and just rebuild the alternator yourself. It's very easy to do. If you know how to take the alternator out and put it back in, you have enough skills to rebuild your alternator. This guy https://alternatorstarterrebuildkits.com/ even provides videos on how to rebuild the alternators. I've heard stories of reman alternators only having the faulty parts changed, not the half worn out parts changed. I've had "new" devices fail (an ACDelco starter to be specific) fail.
alaska_guy
Alaska
2005 GMC Yukon XL
Wait wait wait... cluster is not original? Yours vehicle is a 2005 model? Sounds like you may have the symptom of putting a 2003 cluster in a 2005 vehicle. I thought this started due to radio. Need more info.
M
mo2058130
Long story short I was given another cluster by
after he botched my original. I am not happy but he’s got my original cluster and my money. So this cluster definitely has issues. I did not think this was one of them. I wouldn’t know how to fix/check whether the batt indicator being on has anything to do with this cluster.
2005 GMC Yukon XL
jeffsyukon
Looks like your charging system is working. You could pull the battery dummy light bulb if it bothers you.
Sent from my SM-G965U using Tapatalk
alaska_guy
Alaska
You can't pull the battery light, it's a SMD led. Pm me and I will have you touch base with 2 of the guys in the lower 48 I trust. Use which ever is closer.
alaska_guy
Alaska
My money is on that's an 03-04 cluster in an 05 truck. I just had to remove the light for someone this past week with the same symptom.
M
mo2058130
Agreed, the whole experience was a nightmare. He messed up my mileage the cluster is damaged and now this.
Never do business with GM Gauge specialists.
I’ll swap it out ASAP but with three kids it’s in the back burner.
2005 GMC Yukon XL
fishcop076
