Volant
w140amg
Will a volant CAI fit on a Suburban with a 3 inch body lift?
Stock intake system seems okay.
The fender hole would be 3 inch higher than a stock truck....
Would most likely have to mod it...
W
w140amg
Would the K&N intake. 57-3013-2
be okay then??
Hmmmm
AtomicHoe094
Atomichoe094
cleveland, OH
what yr truck? the volant for the TBI is a struggle to get on, so take Pats name for it if you have a vortec motor..
W
w140amg
1999 k1500 suburban w 3 inch body lift....
Looking at the Volant 150576 with the dry filter and 100K power core filter....
"Increase performance up to 18 horsepower, add 40 lbs of torque and even save gas mileage with the Volant Cold Air Intake System! The rocket scientists at Volant have truly outdone themselves with this one.
The Hi-Flow Velocity Air Box breathes in oodles of performance-enhancing air via the massive air duct. Many Volant Cold Air Intakes also include an enclosed air box that takes power and efficiency higher. Some drivers even report an increase in gas mileage by 1 to 2 miles per gallon. What's more, it can take less than an hour using standard household tools to replace the old, suffocating factory air box.
Best yet, Volant gives most vehicles a performance filter choice: the original high-performance cotton-gauze filter with cleaning intervals of 35,000-50,000 miles, or the oil-free PowerCore® air filter, requiring maintenance after a whopping 100,000 miles."
Just so that you know those performance numbers they throw out there to you are WAY exaggerated. I'm sure you knew that already but just thought I'd let you know in case.
What? Is it more like 50 lbs?? :laughing1:
TallHoe 96 OBS
