Vehicle Settings Not Changing-2015i Yukon Denali
eli_inc
Having some issues changing the following settings. I can go into the settings and turn the settings on/off but they don't take effect. I have tried both key fobs with no success. Anyone else seeing this issue?
Settings
Turning Heated seat on with remote start
Auto folding mirrors when in park
Remote left in vehicle chime
Like I said, all are turned on but the functions don't work?
TheAgency
Minneapolis, MN
Congrats on the Denali, must be pretty new if you've got an "i".
Make sure you are holding the lock button down a few seconds on the remote in order to trigger the auto folding mirrors in park function. I know, it's a bit misleading, but they do not automatically fold in when shifting to park-you need to hold that button, which is a bit redundant with the keyless system.
Heated seats & wheel do have a threshold for outside ambient temperature when remote started before they will come on, keep that in mind.
No answers on the remote left in vehicle.
E
eli_inc
Thanks! I will give that a try.
Anon2015
...and what is the temperature threshold?
Reels
Senior Member
10 degrees today and my heated seats would not come on with the remote start. Everything is on Auto as far as I can tell.
E
eli_inc
My heated seats did not come on today either. It appears we are both in Iowa so it should definitely have been cold enough.
SVL
Libertyville, IL
I have had the exact same issues...can make the changes in the menu but they don't take effect. I've had the truck back to the dealer so many times already for the "Service AWD" error that I have not even bothered to take i back for this issue yet. I have a list of other issues as well - will get around to it at the first oil change.
I love the style...but my $75k truck is horribly engineered and built.
fszatko
WI
Same issues.
Heated seats do not turn on when remote start in the cold.
Cooled seats do not come on when remote start in warm weather (got the vehicle in September).
Also when I turn HD Switching OFF with the radio, the radio still flips in/out of HD mode. Very frustrating since I'm on the edge of good HD radio territory outside Milwaukee. Sometimes, I double-check the HD Switching setting and it's stuck in OFF. Won't let me change ON/OFF, but radio still flips back/forth in HD mode.
razor488
How do you make the horn stop chirping when you leave the vehicle with the keys?
worleytrev93
