Upgrading to 07 esky front brakes
Pachanga02
Ny
My question is will I be able to swap onto my 02 Yukon xl Denali front calipers and rotors from an 07 esv and will I be able to do the rears also. I would be able to get all the parts from the esv so all oem gm parts since it's totaled. I looked around and read that the 07+ tahoe setup was a direct bolt on but just making sure this is a direct bolt on as well. Thanks in advance for the replies.
06xl
MD
The rear should fit right on simple swap FYI the rear rotor on the nnbs is the same size as the rear nbs
Pachanga02
Pachanga02
Ny
Will the sway bars fit and are they any different? The front bar looks to be thicker then my stock bar is there an advantag in swapping sway bars?
06xl
MD
I'm not to sure about the sway bar since its a esv but if it looks the same only thicker and the mounting location and bolts/screws are the same I wouldn't see why not.
Thicker = less sway more control
I am here: http://tapatalk.com/map.php?k10ywk
Pachanga02
Pachanga02
Ny
Thanks I'll look into that. Finished the brakes and they feel great. Best mod I've done yet
Pachanga02
Pachanga02
Ny
Best thing with this upgrade was that I got brand new rotors and pads for free. Definitely something to upgrade.
a4edwin
ny
is it worth it for 24's or do you think it would be better going with a bbk?
glazar
