Updated pics Z71 Hoe
brentlaborde
A few people on here asked for some more pics so here they are.
Since the lift I've added a 1.5" pair of wheel spacers to the back to even out the track width after the lift. Front is 84" and rear is now 84". Rear WAS 81" after the lift. Confused? If you decide to lift your Hoe your front track width is going to increase (for MOST quality lifts) by about 3" total.
Here are the pics:
I was wondering on the rear spacer. I just installed a 6" BDS lift a few weeks ago and notice that the front tires stick's out pass the fender flares and the rear are even, it that a issue. Do i need to get the spaces and if so how much are they and can i install them. Thanks I got one other question to ask if you got time.
07warwagon
The spacers will run you about $100 for the pair on jcwhitney.com and yes you can intall them yourself.
brentlaborde
Here are the pics:
Hey i was wondering if you have the Stabliauto braking system? If so has it come on when you make turns going about 25 to 40miles per hour.
Thanks
Zed 71
Pacific NW
Are you talking about stabilitrack (or whatever it is called)? It should not come on during the conditions you described. It seems like it is sensing a difference in wheel speeds among the tires. What is the difference between front and rear track widths with your setup?
FYI, I have not seen Seel on this board for some time. It seems like you are having a lot of issues with your lift. I suggest making a new thread listing them and hopefully people will chime in.
Machinist2128
