Tune Up
Robin Derrick
So I'm going to be doing a tune up on my 02 this weekend. I've got the AC Delco Platinum plugs, what spark plug wires do y'all suggest?
jarydM
Lost in the Woods
Tennessee
I bought the Magnacore Wires and love them. It was a noticable change in the way the truck performed from the old (150k miles) wires. Most people suggest the ACDelco, as these trucks seem to be finnicky about certain things.
I also used ACDelco Iridium plugs.
cmc76
i used the delco replacements. Everything went fine, with the exception of i had a tough time getting the new plug to thread into the drivers side front cylinder, i forget which # that is. Thought i had stripped it, but after some patience got it back no issues.
Robin Derrick
Robin Derrick
Which mm did you go with? I was looking at the 8.5, but not really sure if I need that or not. The truck has an intake and exhaust on it.
jarydM
Lost in the Woods
Tennessee
Which ACDelco's did you use? I can't seem to find the Iridium ones.
41-110
they aren't listed as an application for our truck because they still only list the platinum. But this is the direct replacement for the platinum -> Iridium.
**EDIT**
I bought mine at AutoZone with the assistance of a helpful employee there.
jarydM
Lost in the Woods
Tennessee
Also, be ready. the plugs for cylinder #8 and #4 are a PITA.
on #4 (the closest to the firewall on passenger side, you can remove the mount bolt for the oil dipstick and wiggle it out of your way, but its almost easier to get to from the wheel well. #8 (closest to firewall on driver's side) is just a difficult damn job.
Robin Derrick
Robin Derrick
**EDIT**
Thanks!
Danny3737
I removed the inner fenderwell cover to get access to the hard to reach ones.
Believe me, this tiny extension on the plug socket is the way to go. No need to remove anything, nothing else needed. It makes it so easy you'll be amazed.
David Paul
Central NJ
I had the same problem. Got the plug in and am hoping it's not cross threaded. No leaks or issues for 10,000 miles.
Danny3737
It helps to put a little dielectric grease inside the boot to help slide it over the plug
hessdawg
Ac delco has $3 off each iridium spark plug
$2 off platinum rebate going on right now
LaOrange
River Ridge La
Hi All
I put a little anti seize lubricant on the threads.
I changed the first set at about 100k and getting ready
to do it again as I have 207K miles now. I changed the wires
the first time.
Danny3737
I really don't like putting anti seize on the threads because there is a good chance of over torqueing and stripping the threads. Its a big no-no when installing plugs on aluminum heads. I just thread them down until snug, then give and extra half turn.
Conedaddy
