trickin out autoride question
goozdenali
Banned - Bad dealings with members
massachusetts
Hey guys I installed my 3/5 on my denali. Will trickin out autoride like max explained with the resistors eliminate both the ''service ride control'' and the ''service stability''? Cuz both errors came up, and I also got ABS light on, I did swap out my spindles and needed to disconect that plug off the hub. And last ?? Wat is the TC light? I'm thinkin its traction control, I may be wrong but all this came up after lowering truck any ideas?
goozdenali
goozdenali
massachusetts
Front
Mcgaughy torsion keys
Mcgaughy spindles
Stock auto ride shocks
Rear
5"drop coils
Mcgaughy drop shocks
Trailing arm relocating bracket
New endlinks
Helper bags
---------- Post added at 08:12 AM ---------- Previous post was at 08:11 AM ----------
Front
Mcgaughy spindles
Rear
5"drop coils
New endlinks
Helper bags
NathanJax
Vacation Nathan
Jax, Fl
Front
Mcgaughy spindles
Rear
5"drop coils
New endlinks
Helper bags
The new shocks in the rear are why your getting all the codes. All you should have to do is remove the negative off your battery, wait 10 minutes, pull your RTD fuse under the hood, connect your battery back, and it should go away.
goozdenali
goozdenali
massachusetts
i tried that but i didnt remove the negative off the battery wen i did so ill give it another try that way. and by the way your escalade is lookin nice, lowering it was the best thing you could of done!!
---------- Post added at 10:51 AM ---------- Previous post was at 09:20 AM ----------
so i took out that RTD fuse and it did help with the "service ride control" cause that went away. but im still getting "service stability", ABS light and TC light
NathanJax
Vacation Nathan
Jax, Fl
Thanks :Handshake:
The problem with NOT removing the negative on the battery is what's wrong. I think the only way to fix it is going to be connecting everything back up to factory, letting itself clear the codes, and then redoing it the proper way.
You shouldn't have to actually put the rear shocks back in, but plugging them in...
goozdenali
goozdenali
massachusetts
so I should put the fuse back in, jack it up to normal hieght, plug in the the stock shocks, then try to clear the codes by disconnecting the battery and pull the fuse back out?
NathanJax
Vacation Nathan
Jax, Fl
I would...
then try to clear the codes by disconnecting the battery for 10 minutes and pull the fuse back out
goozdenali
goozdenali
massachusetts
Hey nathan so I tried wat we talked about but the only code that cleared was the service ride control. Any other ideas, I'm gonna try again
NathanJax
Vacation Nathan
Jax, Fl
Maybe u need to re-install them and drive for a little while before it will clear itself out...
goozdenali
goozdenali
massachusetts
I don't know I'm thinking maybe the ABS light and the service stability go hand in hand since that sensor does read stability as well. Maybe wen I took the sonsor off I might of damage 1 of them the ?? Is wich 1.
vsaravia
