Towing Question
BLKTah02
Gonna tow my 69 Nova to the racetrack, just bought a Curt class 3 trailer hitch for my 02 tahoe, i have 116,000 on my truck, will my tranny hang in there?? it looks like i have a tranny cool already there from the factory, just looking to see how the stock trannys are and how these trucks tow and pull it will be the first time for me
godoy
utah
When I had my 01 Tahoe I pulled a Nissan 240 from Vegas to Orem ut
Around a 6 hour drive
Total weight was around 5-6k I think but Tahoe did just fine no overheating at all
But gas , I think I was getting like 8mpg goog like 70-80
Sent from my HTC VLE_U using Tapatalk 2
BLKTah02
BLKTah02
Wow thats good, yea my car only weighs about 3000lbs, just keep hearing that these trannys are kinda weak
godoy
utah
My used to be Tahoe had 206*** miles and it pulled it just fine :)
BLKTah02
BLKTah02
Cool thats good to hear!, yea mine has 116k on the clock
BLKTah02
BLKTah02
so i guess theres no reason to put aftermarket tranny cooler since i already have one from the factory?? that should be fine?
godoy
utah
That should be fine
Even if you didn't have one it'll be fine
livingez_123
Sandy, OR
I tow a 32' trailer behind my Denali and my trans temps never get above 200deg. if you notice the temp climbing on a grade just pull it out of OD and run it in direct. OD adds a bunch of heat when climbing or even in a strong headwind.
BLKTah02
BLKTah02
Thats pretty good for that much weight, im guessing ur truck came with a trans temp gauge? or did u put one in??
yea mine has tow/haul mode so i would just leave it in that mode
BLKTah02
BLKTah02
or can i put a scanner on it to see how hot the trans is getting?
a4edwin
ny
i you really want a gauge just buy a cluster from an escalade, denali, even some of the pickup's have them. it's simply plug and play. only your mileage won't be the same.
BLKTah02
BLKTah02
and u wouldnt have to hook up anything extra behind the dash?>?
BLKTah02
BLKTah02
going to tow on may 31st 4 hour drive with a 3000lb car, let u know how it goes, tranny was serviced just under 100000
Conedaddy
