Tire fitment
A10MileHusker
Beaverton, OR
I didn't find anything but do need a quick answer so I apologize if it's been discussed.
My AT4 is going to be shipped to me this week and I'll get it a few days later.
I currently have a GX550 and I have 22" Vossen wheels with 285/55/22 tires. I'm thinking of buying some cheap takeoffs on Marketplace and putting the Vossens on my AT4.
Will those tires fit?
Kpwweb
Those tires may rub being 34.3”, especially if the AT4 is stock height. The stock tires are almost 1.5” in diameter less.
The other thing is the wheels may not fit. Depends on bolt circle and center bore diameter, along with offset.
KMeloney
Have you read somewhere that GX550 wheels fit these GM suvs??
tsuintx
DFW
Interestingly enough, at least according to the famous AI dude on Google, the bolt pattern is the same. Now, whether the rest of the specs, offset, center bore and such are matching needs more investigation, but I guess OP has done it.
KMeloney
I think there was a Toyota (?) wheel that was rumored to bolt up to my '09 Tahoe... But even the '09 Tahoe wheels have a different offset than the current models.
Def interested in learning what the OP knows about the G-wheels bolting up to these trucks.
A
A10MileHusker
Beaverton, OR
I am getting the same information you guys are talking about. I haven't 100% confirmed but the information I was able to find, they seem to be the same bolt pattern. I am making some calls today to find out more.
Thanks for the feedback so far.
LewL
The AT4 needs a 6x139.7 bolt pattern. Offset will determine whether they poke out. A positive offset will have less poke and a negative offset, more poke. +20-30 mm not much poke. -18 poke. -44 lots of poke.
Towmaster
