2005 Z71 Tahoe (non-flex)
Within the past month I have had the following happen, which suggests to me that they are all related:
- "Tighten Fuel Cap" message on dash
- no codes stored
- random starting issues; sometimes the starter will crank 2-3 times as normal and it the engine will fire right up, sometimes I get a half-crank out of the starter and it turns over, sometimes it's a half crank and the engine dies out, once (so far) I had a 6-7 second crank until the engine started.
Troubleshooting / repairs so far:
- new purge valve (last year)
- new purge solenoid (last year; on top of engine)
- new gas cap (last week)
At first I thought I was having an issue with the starter solenoid until I got the "tighten fuel cap" message to come back this week. Now I am wondering if I am having a fuel system issue somewhere and/or vacuum leak. When I turn the key to the ON position I can hear the fuel pump getting power no problem but I do not know of a way to test anything out with the fuel system.
Are there easy things to check myself before taking it to the shop?
- no codes stored
