Throttle Body Hard Start
mmeachem
Gonna clean my throttle body tomorrow and I heard that it will be hard to start
How hard and does it really pay to clean it
ATL
yes clean it! it may stutter alittle trying to crank back up but nothing to worry about
blrmkrl83
Iowa
Both my 00 Silverado and 01 Suburban had throttles were sticking closed. I just sprayed something like carb cleaner for fuel injected systems (throttle body cleaner maybe) in there to clean off the buildup of gunk. They worked great after. I don't remember them starting hard after I sprayed them, so if they did it sure wasn't much worse than normal. Just don't spray half a can in there and you'll be fine.
ATL
while you are getting throttle body cleaner, grab a can of mass air cleaner also. when you go to clean throttle body, take air inlet pipe off and pull the mass air out. spray it with mass air cleaner ONLY, never touch the wires, and let it air dry COMPLETELY. but itll dry completely while you clean your throttle body. use an old tooth brush to get in there good. clean the throttle blade seating area very well, and use the brush to clean where the throttle blade pivots from. after you scrub and spray, wipe it down as well as possible with a shop rag. then reconnect mass air and inlet tube, all done
mmeachem
mmeachem
Yeah I'm doing all this cause I'm getting my Spectre 9900 today and it's coming with mass airflow cleaner and throttle body too
01HDtahoeNJN
Shredding Gnar Daily
North Jerz, NJ
Mine was dirty as hell but the start up was "rough" afterwards just that one time after that no problems did the MAF too
vsaravia
