Thermostat Not Closing All the Way?
2006Tahoe2WD
Silicon Valley
The other day I drove over Sonora Pass CA. On many of the downhill sections I noticed the water temp. dropping a considerable amount (to the quarter point, 150F?). It was not very cold outside (50F). I don't recall any issues in the past with the cooling system able to keep the engine at a constant temp. Anyone else have this happen? Could be time to change out the thermostat?
GMT800 2005 Tahoe Z71
Navy Supporting Member
I would not worry about it. Cooler 50 degree air on an engine that is not pulling can cool an engine down considerably. I am assuming, since you did not say, that the temp gauge looked normal when back on level ground and just maintaining speed? When you were pulling up the hills/passes, where was the temp gauge?
2006Tahoe2WD
Silicon Valley
Pulling up the hills and all other situations the temp. is steady where it always is. I expect the thermostat to keep the temp the same in all situations except maybe at the very extremes.
Geotrash
Dave
Richmond, VA
Yes, this is a common failure mode for thermostats. I had an isuzu rodeo that started doing this and not long afterward the thermostat stuck shut and it started to overheat. I caught it before it got too hot, thankfully.
I agree with @OR VietVet that it’s not an issue as long as it’s sticking open and not closed. But if it changes it’s mind… ;)
NickTransmissions
Sin City
The transmission bench
Perfectly normal, especially at elevation where temps are cooler like Sonora Pass (9500+ feet). My 03 Tahoe behaves the same way on downgrades. Won’t hurt a thing as it comes right back to normal op temp once I’m back level or start climbing again.
That said, preventative maintenance is never a bad idea.
Foggy
KS
Not sure what year/info model you drive, but the factory temp gauge is really
just a "suggestion".... It's so far off that I rarely even look at it.
I read it thru my scan tool or my diablosport monitor.. you wouldn't believe how far
off it really is
Charlie207
LFOD, New Hampshire
off it really is
Comparing my dash gauge and the actual temp via Torque Pro, I see that my dash gauge doesn't even start to move until the coolant temp is approaching 140-150*.
brice715
