The twin hoes plus one
Sparksalot
Sparksalot
Bastrop County, Texas
The auxiliary wiring had been chopped out of thecopcar. I didn’t realize that until I got Lola.
I’ve taken advantage of the grommet to route a bunch of stuff through the firewall. I’ve reached the limit. I had to pull the terminals out of the connector for the ditch light switchlegs to get the cable through.
822A5E67-42A7-4D3B-A36D-38A04C9A4148.jpeg 629E4AE6-3A8F-4F86-A4B1-ABCA675B8195.jpeg C570E118-25CA-478D-8D21-284FD5D64C00.jpeg 835DA5DF-097F-4F42-B3F0-5DE51E910CFD.jpeg 72BA0825-3573-4EFE-B6E2-661CEEF963AA.jpeg
Sparksalot
Sparksalot
Finished the trim and mechanical part of the DIC installation in thecopcar today. It’s going to be weird to get into Lola now and see the blank patch. She’s up soon.
because the trim is specific if you do or don’t have this, I spent some quality time with a dremel and a small sanding block.
the result turned out well.
4E1404F4-C00C-4487-B65E-5788CCEF495D.jpeg A69B7C0B-8B22-48D3-A4D1-845E03A3B322.jpeg EAF370CF-E468-451C-A449-4BEF69880433.jpeg 4B7355F8-7D8E-41F8-8D76-3601CE5AC333.jpeg
Bill 1960
Testing the Limits
Wow, they’ll see you from outer space with those lights on!
I’d like to hear your review on the fridge after you get some time in on it. I need one later.
NOSOK
Colorado
This is more of to-do but I noticed the truck has been leaving some drops on the driveway lately. If I drove more than the ~50 miles/wk I do currently, I would've looked into a while back, but as is, I've been procrastinating...hopefully it's just a loose oil filter.
NOSOK
Colorado
whoops meant to post this in the what did you do thread.
I had yours opened to see how you mounted the fridge
Sparksalot
Sparksalot
No worries.
I made a platform to clear my water tank, plus give space below. I waited until the fridge arrived then mounted some eyelets to attach straps. For now heavy bungi holds it, but I may do something else.
Sparksalot
Sparksalot
Now both of the twins will have a DIC. Lola will get the spiffy brushed trim.
I found a dash trim with DIC for a song on fleabay. It was woodgrain. Boo. WAS woodgrain. Now it’s flat black, and in thecopcar.
AE236942-C793-48B5-AF76-018FF28879E8.jpeg EFA3BFEA-BFC2-46AC-85AC-F6172F12F11A.jpeg
Durobans
