Chevrolado
The vehicle: 1995 Tahoe 5.7L with TBI
The problem: sporadic idle, jumping from too low at 400ish RPM all the way up to 2000 and everything in between. Also occasionally will not start. Then once started, idle jumping again. Will not stay still.
History: this truck had a Venom 400 module put on it (spliced into the TPS wires as directed for install). If you dont know what those do;
So it had never worked right from the previous owner, so it was turned off, but still wired up. Well the other day I was driving, it started going crazy on idle and jumping all over. I decided, you know what, I bet its this weird splicing in of this box. So I removed it all, electrical taped the spliced portions, and put the wires back into their looms and drove home.. It worked great for a little bit. Then all of a sudden, started going EXTRA crazy.. Then hard shifting into each gear. Then "Service Engine Soon" light.
Got it home, and finished pulling the entire unit out with wiring. So now it's back to stock. It still had the idle jumping issues so I cut the spliced wires and reconnected them with some wire connector crimps in hopes it was just not getting a good electrical current..
I also found this issue in the gasket for the K&N intake:
So after I finished all of the electrical fix and repaired this gasket.. Hooked the battery back up and it started RIGHT up and ran better than I've seen it. Took it for a test drive and it was great all the way to the store. Turned it off, went in, came out it started right up again and then on the way home it went crazy again!! What the heck?
Unhooked battery, waited, hooked battery back up and it runs fine again.. This time not wanting to chance it, drove it to the shop and left it for the mechanic to look it over tomorrow..
Anyone have any ideas?? I want to fix this myself but at this point I'm at a loss. I just don't know enough about these yet.. Any help would be greatly appreciated.
Thanks!
Venom Performance Control Module - Venom 400 Engine Management Piggyback
Achieve horsepower gains up to 25% over the mid-range 1,000 to 5,000
rpm. The venom 400 is and add-on control unit that features its own
micro-controller. This module is connected to the vehicle's sensors and
increases engine performance by monitoring the sensors output
characteristics and modifying the input signals to the vehicle's
existing computer. The unit activates at about 25-30% Throttle Angle
and tells the ECU to provide a more aggressive set of fuel and ignition
maps than it would normally provide.
Thanks!
