Subwoofer remote control knob
Qlassic418
i am in the process of installing a subwoofer and amplifier in my 2016 yukon slt.
I am looking for the best spot to mount my sub remote control knob
Can i have some ideas please
L's Truck
DC Metro
Mounted mine in the space where the 2 usb ports are in front of the cupholders
Brooklyn hoe
Unit171
NC
I like that. Does that piece just pop out?
L's Truck
DC Metro
I just pulled the whole console (cubby, cupholders, etc) and drilled from there. I missed my mark because I wanted it further to the left but whats done is done ahaha. The console containing this cubby and cupholders just pops out.
Q
Qlassic418
This what i am going to do i think
But i have a yukon slt not a denali or ltz so i dont have the cover to hide it after but i don’t care
Did you use a line output converter to run your amp
L's Truck
DC Metro
Yea it shouldn't matter with the cover. Only person to see it will be you and maybe the passenger.
I used the LC2i. the knob I have is for the LOC not the amp.
Q
Qlassic418
I am doing the same thing. Where did you tapped your wires for the lc2i
Q
Qlassic418
The is 4 different diagram for the amplifier
How do i know which one i need
Q
Qlassic418
I have 2x500 watts rms subwoofer
1x1000 watt rms amp
My question is do i need a capacitor or do the big 3 upgrade or none of that and ill be fine
Unit171
NC
Have you adjusted your LC?
When you say it does nothing.... what are you referring to?
Do you have power to your LC? You also have to ground it too. You can tap into the power wire on the factory amp plug to power the LC. Then you can use the bottom bolt on the factory amp to ground your LC.
ibarra503
