Sub Setup suggestions needed
B12
Fl
Right now my setup is a jl w3 in a sealed box was wondering if a ported box would sound better.
Crowder99Yukon
If you want louder then yes. Depends on your taste. If you listen to rock then sealed is usually the better choice on a sub like that. But if you listen to bass heavy songs such as rap then you'd want a ported box.
Sent from my HTC One S using Tapatalk 2
B
B12
Fl
Ok it sound a little sloppy in a sealed box could that be the reason
Crowder99Yukon
Shouldn't really sound sloppy in a sealed box. What amp are you running?
B
B12
Fl
its a jl jk500/1 and its been overheating so i'm switching to the jl jx500/1d.
Crowder99Yukon
What's your gain been set to? I'm try turning that down first before buying a new amp
B
B12
Fl
Not a big audio guy what is the gain for? And I'm changing the amp out because it heating up and going into protection mode
Crowder99Yukon
Its probably going into protect because the gain is too high. Try taining turning the gain dial to about half. And see if it still overheats
BEEMDUB
PIMP DADDY FLEX
Michigan
Just know that the gain is not a volume knob....It's to match the preout voltage of your H/U....Technically the best way to set your gain is with an SMD DD-1 or Oscope....The next best thing would be to turn your headunit to its max point without distorting audibly, next play a -5db test tone (you can download them all over online) and play it through your sub, slowly start to increase the gain on the amp until you hear your subs to stop increasing in volume and distort, then back it off a little bit.
B
B12
Fl
Ok thanks I pretty sure my HU has a 12v output
Charlie21ny
