stupid interior light
96GMCYukonGT
ok so my interior light works but doesnt turn on when the doors open any ideas?
96GMCYukonGT
96GMCYukonGT
do they pop out or do i have to go up under the dash to change em
GMC Yukon
OK so on the light switch. lower left side is there a round buton ? If there is .is it pushed in. If so turn your key on open door and push it so it comes out.... Dome light shoul be on now!
onlygm4me
Molalla, OR
Does it come on when you open the other doors? If so it's like mine and it has a bad driver side door switch. Hope some can tell us the best way to remove/replace this switch, I haven't taking the time to look at mine yet.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
If it does not work with ANY door open check the bulb or dome defeat circuits. It would still let the courtesy/dimmer switch to work the lights. Otherwise all you door jamb switches would have to be bad.
the 18th letter
Northern New Jersey
On the 99's there a overide switch near the light switch on the left. I PURPOSELY make my interior lights stay off when opening the door.
grnrpr68
Davenport IA
bad door switch on the side of the dash. override switch near the light switch on the left
96GMCYukonGT
96GMCYukonGT
its only a 2dr and its just the switches then cause i can turn it on with the switch on the dash but im just a forgetful ****** and will end up killing my battery
Sparkybuilt63
