Straight axle my front end
Casper1213
Im thinking about install a straight axle on my 99. But really don't know how much work that would Intel and if it would be worth doing in the long run.
MadDogDelpho
Texcellent
Texas
It's a pain in the ass. Plenty of threads around on how to do it, but it's a lot of time and money.
Casper1213
Casper1213
Sounds like a challenge I like it lol. But is it as hard as doing it to a 90 suburban. Because if it is ill just lift it an call it a day. Cause I have the time. But I really don't know how much it would be on a 99 tahoe.
MadDogDelpho
Texcellent
Texas
Weren't 90 model year Burbs squarebodies? They should've come with straight axles. Anyway, the OBS's (1995-1999) are IFS so there's a bunch of cutting and welding etc. required. I think there are kits, but again, it's expensive.
Casper1213
Casper1213
I had bought a 89 1/2 ton with a 454 an turned it into my mud toy an it was independent in the front.
lukc22
There are kits for whatever vehicle you have really... You just need to make some decisions first... What size tires are u gona run and how hard are you gone beat on it would probably determine what axle you need up fron... Also, do you wana go leaf or coil... driver or passenger drop.... I have a 97 with a solid front axle.... I didnt do the swap, bought it like that... I was researching it alot when I had a 99 z71 though
Casper1213
Casper1213
IV got a 99 and Im just wanting to put some 33s on her possibly 12.5 wide and Im not going to be beating on her all that bad being that she my daily driver/ grocery getter. Just looking to go out on trails with the kids an wife on the weekends an things like that. Would you have a ball park figure on price on a kit or axle. Im doing the labor part of it.
lukc22
To be honest, I wouldnt do an sas for 33's and weekend wheeling... I had 35's on an ext cab 99 z71 and it did just fine... You could do a body lift and fit the 33's... But to answer your question:
There are lots of ways you can go.... cheapest way is a dana44 front and keep your rear axle... A d44 would probably run you 400 and then you would want to rebuild it with new seals... you will have to regear, and get a different front driveshat.... Offroad designs will have an ifs to sas swap kit for around 800 i think.... then you need springs and shocks etc etc.... I think an SAS can be done for about 5 grand on the cheap cheap side...
Again, I would not do that for 33's and weekend wheeling.... If you are OK with spending 2k then get a badass 6" lift amd be done...
Casper1213
Casper1213
Yea I thing ill do the body lift then. And get a lift kit down the road. Tuanos man.
Dneel81
OKC
I'm eyeballs deep in a SAS now on my 2 door tahoe. I'm 5000 in the hole and still need two new driveshafts. At 500 a piece I'll be 6000 in the hole in no time. Totally not worth the effort for anything 35" and down. No dana 44 will be made worthy of a full size for less than 1000 no doubt.
Casper1213
Casper1213
Alright thanks man. An yea I just wanted to do 33s and from what Iv gathered a 3 inch body lift will be more than enough.
briannorris
