speakers in barn doors?
druiddonn
I've looked all over and haven't found anything about this does anybody have any experience or info about adding speakers to the barn doors?
trevcda
What are you hoping to accomplish with speakers in this location?
For a full range speaker, they are too far back and too far below the back seats to be of much use for the front seats.
As a subwoofer locations, the airspaces are too small and not adequately sealed enough to provide a good sealed acoustic suspension chamber, without significant modification.
If you were just wanting to shove a pair of speakers back there so that the doors could be fully opened for a little bit of music at a tailgate party or camping trip, it would probably be fine.
getonerd
dayton oh
Well q-logic makes subwoofer boxes for the barn doors just need shallow subs. Well for full range speakers unless you doing some tailgating u could put speaker their but I would fiberglass on top of the panel u could l get some mdf ring and make an little door speaker setup otherwise it not worth doin
trevcda
$249 each, plus drivers? That's a significant modification to your wallet! Really cool idea, but with that depth and airspace, you would be really limited on sub driver options and performance, although a pair of JL 10W3V3 subs might just squeeze in there and would be about right for depth and sealed airspace. Actually, that might actually pound pretty good!
http://www.jlaudio.com/10w3v3-2-car-audio-w3v3-subwoofer-drivers-92150
druiddonn
druiddonn
Well i use my tahoe for work the back seats are allways folded down mostly im looking one more place to add a set of speakers i dont know wear the sub will be but probably not in the barn doors
getonerd
dayton oh
If you have any woodworking and done any fiberglassing
I made this when I used the back
Sent from my Venue 8 3830 using Tapatalk
  • Like
Reactions: Lon
qukon 95
i put a pair of kenwood 5x7 in my barn doors for when i'm watching movies sitting outside. i did form a encloser in the doors for them plus i pulled the carpet off the panels and cut the hole and glued carpet back on you wouldn't know speakers are there. DO not use thick gauge wire it will
get pinched when closing the doors. i did have to drill some holes for the spk wires. i'm not using
the 4x10's. look in my www.photobucket.com/qlcp
mudpup
texas
No,but hope you find some info.I would like to do this on my 96
druiddonn
druiddonn
I found a set of kenwoods 4x9 at a yard for 9 bucks a piece after installing them i realised thats all i need. The lmc catalog shows the doors without the trim panels if thats any help. After a new deck ill reconsider but i dont think it will help me iv allways got the back full of stuff.
jk6062
