something wrong
white_lexie
I swapped out my old steering column for another and now everything on my dash stays lit up. The cluster has both blinkers lit up and everything but they are flashing on the outside, I dont have a clue what the problem is?
Gzes
the drifting 2dr
Wichita tx
Why did you switch it out? The wiring in my old silvi had cut up wiring so we had it swapped out and it worked fine. Maybe the one you got is shorting out
W
white_lexie
The blinker and hi/lo beam lever switch had went out and I bought a parts truck with a good one and it was easier to swap the whole thing instead of the switch. It worked fine in the other truck, thats what has me baffled.
W
white_lexie
Done a little more work and its not the steering column, and its not the on/off switch for your lights either.
agjackson1981
