SOLVED Odd shaking initial drive
ukrkoz
Auburn WA
07 Tahoe LT
Developed weird shake in the morning.
After I start and take off, drives fine until I reach arterial, which is about thousand feet away. On arterial, it has strong shake for about quarter mile.
My entire left leg and buttock shakes vigorously up down.
After quarter mile, shake disappears and truck drivers fine.
The colder outside, the worth it gets. Truck is parked outside.
Definitely not the road as scooting across tarmack or even into the incoming lane doesn't change anything.
When it's hot outside, no shake.
Tires are only about 7 months old.
Rear air shocks aftermarket. Airbags work fine.
Any ideas? Far I know, shake in the floor and buttocks points at the rest end. No shake in steering or dash.
B-train
Couple thoughts:
1. Tire malfunction - shifted belt or other. Have them road force balanced. You could also move the backs straight to the front and see if the vibration follows. You can also try watching rhe tread pattern in dust, or when wet, on a hard smooth surface to see if anything weird shows up in 1 revolution
2. U-joint that is tight and loosens up with some movement. Drop driveshaft and inspect both joints for free movement. If there's any sticky or tough areas in the range of motion then replace.
Geotrash
Dave
Richmond, VA
It lasts only about 15 seconds at 40. That's what beat me. And after work drove like butter.
It's only in the morning and only when cold.
And is the shake/vibration at the frequency of wheel rotation or driveshaft rotation (3.x times wheel rotation speed)? If it's at wheel rotation speed, I vote either broken belt/cord in one of the rear tires, or a bad/damaged wheel hub. Are you running any wheel spacers, by chance?
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
I hate wheel spacers. That's a dirty word.
U
ukrkoz
Auburn WA
All stock, even hubcaps.
Though, I do have a rear tire that has NO weights on it. Found that only like 2 weeks ago, by accident.
Unfortunately, with my work schedule, I can force balance tires only Saturday am, so it's a bit in suspense till then.
OR VietVet
Willamette Valley
Do you mean no weights on the outside or no weights at all, inside or outside?
U
ukrkoz
Auburn WA
NO means none. I do not do rim weights, they fall off, I do sticky only. Rim is BARE. Not a single weight. Peculiarly, there is no balance type shake at FWY speeds. Only at cold take off, starts about 1000 ft from home at arterial speed, for about quarter mile, then goes away. The colder outside - the worse.
U
ukrkoz
Auburn WA
Nope. Tires were installed around late fall last year. Weekly commute is about 300 miles. Shake was going on for about 3 mths...if I recall correct. I DO NOT DO Fixflat. I use it ONLY on my lawnmower.
Geotrash
Dave
Richmond, VA
I'll ask again because it's an important detail: Is the shake/vibration at the frequency of wheel rotation or driveshaft rotation (3.x times wheel rotation speed)?
OR VietVet
Willamette Valley
Ok, as has been said, a tire can have a belt problem that goes away when heated up or the driveline could be the concern. Other problems could maybe be there but these two suggestions are the most obvious. You could move the tires, front to rear, and see if the problem moves.
Also, about the tire weights. I cannot see the tire and I don't know the preferences of the vehicle owner. Details up front, like what was given later, remove all doubt.
CKendrick
