*** SOLVED***Fuel Pump Control Module DTC's
opfor2
Riverside County, CA
***SOLVED***
Ended up replacing the fuel pressure sender and pulling the Fuel Control Module. I cleaned the FCM with contact cleaner and then put a light coat of dielectric grease on the connectors and now all codes are clear. Let's hope that this is a permanent fix.
Good morning, Tahoe Family,
So, I ran a scan on my 2011 Tahoe today and I got the following 4 DTCs under the Fuel Pump Control Module:
P018B= Fuel pressure sensor performance (hand in hand with P2635)
P0562- System low voltage
P2534- Ignition 1 switch circuit low voltage
P2635- Fuel pump flow performance
The fuel pressure seems to be ok when I checked via the fuel rail so do you think that the pump may be ready to go out? I do a lot of remote desert exploring and I don't want to be stranded in the middle of nowhere due to a fuel pump failure.
Good morning Tahoe Family,
Solve the P018B first. May need a new sensor or FPCM. Once that code is fixed, the others ought to go away.
Key on is 58 psi. Engine running at idle and normal speeds is 43.5 psi. WOT is 58 psi.
opfor2
opfor2
I ordered a new OEM sensor from rockauto yesterday and I will replace that first since it’s the easiest and cheapest to do
fredcook
My first "guess" would be an electrical fault triggering the fuel system DTC cascade / chain reaction. I've seen this often on my '08 and '13. A low battery start, glitchy ground, etc., setting off voltage DTC's, followed by a handful of DTC's related to one system or another (fuel, trans, etc.).
P018B and P2653 are symptoms. P2534 and P0562 are conditions. Conditions cause symptoms. In this case, you have two low voltage symptoms, and I venture to guess low voltage was passed to the fuel pump, which either shut down or didn't pressure up, and that set of the pressure sensor.
opfor2
opfor2
Does someone have the wiring diagram for the fuel pump and grounds?
Moderator
People's Republic of Colorado
www.charm.li has info for your vehicle. Hit the link below and scroll down to the Fuel Controls diagrams. Also at the top of the browser page you can click on "Repair and Diagnosis" and select your DTCs for the diagnostic paths:
EDIT: for ground locations see the link below for an example of where G300 and G400 are:
opfor2
opfor2
So, I replaced the fuel pressure sensor today with an OEM GM13500745, and hopefully it will resolve my Po18B code. BTW, the old sensor appears to be the original
kikeap
