slight miss ???????
knotty
hey all im new here i have a 96 tahoe and i have slight miss in my 5.7 i have changed the plugs, cap and rotor. i am not sure what else to to any help would be nice thanks ...
foreverfalcon40
Slight miss can be caused from a bunch of things. You have the right idea. But you just pissed away money. Should have taken it to a shop to get it diagnosed and take it from there....
Your cel on? Just asking...our PCMS are good like that.
JKmotorsports
Austin, TX
You mentioned changing your plugs, but what about your wires? Cracked or deteriorated wires can cause arcing and a miss.
When is the miss noticeable? i.e. cold engine, warm. More noticeable at idle or higher rpm, under load, etc.?
K
knotty
the wires are new , the cel is on , but its only at idle ! i have had it looked at and it said the egr valve soi replaced that as well .im stumped
foreverfalcon40
Could be a bent valve...not sealing right. Once you giv it gas it goes away. take off you intake hook up a glove and shoot air through one of spark plug holes. If it blows up you need a head.
K
knotty
ok had it looked at and the code was a mult random cyl missfire i dont know what to do now !:(
JKmotorsports
Austin, TX
Check your intake gasket. That will cause a miss and throw a random misfire dtc. It's a common issue.
K
knotty
intake manifold ? i tested that with some starting fluid and nothing happend with the idle
K
knotty
is there a better way to check the intake gasket ?
destroyer1362
A work in progress
Midlothian, TX
Could be your fuel pressure regulator or a leaky injector, it can cause a mult random cyl misfire code. I believe I have the same problem.
K
knotty
yeah im doing a leakdown test tomorrow, i will let you know what i find out .
blueflamed03
Oklahoma
like JK mentioned, the intake gasket is very common on these, and also check to make sure it's not a wire or a plug, even though they are new, you can have cracked porcelain. Pop the hood at night, while really dark and look for any arcs from wires/plugs/cap
Miami-Yukon
'96 Z71 YUKON 2DR
Miami (305)
I had a random misfire dtc, so I did the plugs, wires, dist cap & rotor & it went away.... No more problems after that !!
K
knotty
lol i wish it was that easy for me , thats all done now i am stumped !
BOSS
The People's A D M I N
Dallas
Check your individual injector wires:
Hook a noid light up to them and make sure you have a stead blinking light (can be rented at autozone) Make sure they are seated properly -check the individual wires that go into the injector plug that plugs into the manifold, check that they are seated properly.
Seen that somewhere in a land far far away....
B
3-lot
Lloydminster, Saskatchewan, Canada
deff. check the fuel regulator, if you crack the throttle plates and can get a small mirror and led light in there, you can see it, or see if the intake is washed down inside towards the back.
also, if an intake has been recently done, pull the main injector plug in, (large rectangular black plug in on top of intake behind throttle body), check to see if any pins are corroded or bent. (i have seen this a time or two).
K
knotty
ok i have it narrowed down a lot ! my # 5 spark plug keeps fouling ! i dont know why :( its got spark, compression , and air ! but its fouling with in mins of me putting in a new plug ! any suggestions ? thanks
K
knotty
too much fuel fouling the spark plug due to a leaky injector?
i just seafoamed my truck and it hardly smoked at all ! my next thing is the injectors how do i check to see if i have a leaky injector ?
vsaravia
