Show Me Your Modified Ride!
LowBurb13
My 2013 Suburban.
My daily beater.
Jason in DLH
Jason in DLH
Cheeseburger and Fries
MN
Nice! What lowering kit did you go with on the Burb?
BG1988
Man, that’s great! I just took off my fuse panel lid and engine cover and about to take off my K&N Intake tube to paint gloss black soon. Lookin’ real good!
are you trying to impress your mechanic??
LowBurb13
It's Mcgaughys Spindles, Belltech Struts for a 3" front drop. Belltech 3"/4" rear kit with free travel mod. I had to cut 2 dead coils off passenger rear spring and cut down a spacer to 1/2" on the left to make it sit level.
rvsatx210
What did you use to paint those pieces? I've been wanting to do that as well. Can you post pics?
Jason in DLH
Jason in DLH
MN
I got sidetracked and haven’t done it yet. Here’s what I’ll be using though:
1. DupliColor Plastic Adhesion Promoter or AutomotiveTouchup.com Promoter https://www.duplicolor.com/product/adhesion-promoter/) OR (https://www.automotivetouchup.com/spray-paint/adhesion-promoter.aspx)
2. Base Specifically mixed and matched perfectly for RPO code found here:
3. Lots of coats of SprayMax 2K Clear Coat:
https://www.automotivetouchup.com/spray-paint/spraymax-2k-clearcoat.aspx
4. 3M 5000 Grit ( or Meguiars Ultimate Compound):
https://shop.advanceautoparts.com/p...deG9lncBSDEx9ZF4UkAaAg8qEALw_wcB&gclsrc=aw.ds
5. Meguiars Ultimate Polish
Bigkevschopshop
Northside H-Town
I agree the ballers do look stellar...
Just Replica 22s with esky tails here... For now, I have some 4" Eibach drop coils here, just need a few more parts to get things done for a drop kit...
Jason in DLH
Jason in DLH
MN
Your ride is looking stellar! I love those snowflake wheels as well! What other parts do you need to get for a drop kit?
Bigkevschopshop
Northside H-Town
Thanks bro, Im trying here...
Drop spindles, I think DJM has the offset sway bar ends for the rear to correct that, and when doing free travel mod plan to put jounce bushings in there to control bottoming out if possible, and helper bags for towing..
Once were good there, then maybe upgrade some sway bars and put some spohn arms on rear etc..
Jason in DLH
Jason in DLH
MN
It was actually converted by the previous owner using all OEM parts from a 2500hd. Works slicker than *** on a gold tooth.
That’s awesome! Miss the throttle response on a manual. Or maybe it’s these electronic throttle bodies that makes my Yukon feel unresponsive. Either way...I miss driving a manual.
varminpoolteam
