shift linkage adjustment?
mm0142
96 tahoe 2wd 5.7 auto
transmission wont downshift into passing gear
I had the cats tested and they are good to go .
I was told to try adjusting the shift linkage on the trans . I have a haynes manual but it just says taht on 96-97 models its too complex to be put in the manual . please if anyone can tell me what to do i would really appreciate it .
ravingmadman
Chief Knuckle Buster
Greater Seattle
HAHAHAHAHA. "You know you're driving a hoe if the haynes manual says it is too complicated to explain, even with pictures."
mm0142
mm0142
thats what i thought bro . i just cant see it really being that hard .I just need to know where and what to try .
hyde
Montgomery, Tx
If it used to work and now doesnt...I would tell you dont adjust anything find out why it isnt downshifting!
destroyer1362
A work in progress
Midlothian, TX
he's talking about the linkage for the kickdown right? Mine does this on occasion as well. I figured it wold be fairly simple to work on.
mm0142
mm0142
yea the trans shifts fine just when i put the pedal to the floor it wil just stall the trans and stay at whatever speed it was at before i floor it and the engine just revs up . never done it before but all i can find on this issue is the shift linkage needing to be adjusted or the cat conv. being clogged up . the cats are both good but when i look in the manual for the same issue it only says to check the linkage and that for 96-97 2wd it was too complicated for them to include in the manual . go figure .
---------- Post added at 06:40 PM ---------- Previous post was at 06:40 PM ----------
if anyone knows of anything else i can check to be possible fix please let me know.
SuburbanPassion95
