SES P0441 code 96 Tahoe 300K
inthechateau
Maryland
So my 96 Tahoe popped a P0441 code. Looked at the obvious, no lines cracked, gas cap on (did not fill while running) and I'm looking for other items to check. have not jumped to the new code scanner yet to dig into history or anything. So layman help is needed.
Thanks
McFizzl
Broke as a Joke.
Fayetteville, AR
A code P0441 could mean one or more of the following has happened:
Bad vacuum switch
Broken or damaged EVAP line or canister
Open in PCM purge command circuit
Open or short in Voltage feed circuit to Purge Solenoid
Faulty purge solenoid
Restriction in EVAP solenoid, line or canister
Corrosion or resistance in purge connector
Bad PCM
There's a start for you straight from the OBD II website.
link: http://www.obd-codes.com/p0441
lilb
