Service 4WD
gbleezy
loves to snowboard
I have a 2008 Tahoe LTZ and when switching from 2WD to Auto, I the light blinks longer than usual but eventually stays lit on Auto. I can also switch it to 4WD High and it stays lit there. However, the Service 4WD message appears on the DIC. Since the light stays solid on Auto and High, does this mean my 4WD is still working?
wjburken
Eastern Iowa
If you are getting the Service 4WD message, get it checked out. Have checked to see what codes are present? Might get under it and make sure you at least have oil in your transfer case.
gbleezy
gbleezy
loves to snowboard
Thanks for the reply. I'm planning to get it checked out, was just curious so figured I'd ask on the forums.
wjburken
Eastern Iowa
No matter what, make sure you have fluid in the transfer case. My 2004 gave me the same symptoms and I before I could get to a place that I could check anything, it turned into a box of gravel because the case developed a leak and the fluid had drained out without me noticing.
gbleezy
gbleezy
loves to snowboard
What's the easiest way to confirm there's fluid in there?
wjburken
Eastern Iowa
Jack it up, crawl under it, remove the fill plug and stick you finger in the hole. Fluid level should be just below the fill inlet. If it is not, put some fluid in.
I believe your transfer case takes DEXRON -VI ATF fluid, but double check your manual.
Kenneth L Nielsen
Probably not working. If you are mechanically inclined we can give you some more tips, otherwise time to take it in...
Eickybobby5050
