Second o2 sensor slow
BG1988
Does anyone have any information of the O2 sensor
I suspect my is slow like super Slow out of a deceleration fuel cut off.....this causes Check engine Light for the second Bank 2 catalytic converter P0430(typically P0420 is the common one when there is a failure aka bank 1)
it's pretty stable at 0.865 to 0.895 but after a DFC it's slow to move from 0.1v unless i give it more gas
sensor 1 jumps all over the place from 0.1 to 0.870
they're not "following"
I end up with a "false flag CEL" · Short Term Fuel Trim (STFT) of +34.5 on both banks...
when running the Long term fuel trim is 3 to 4 range when driving
GMT800 2005 Tahoe Z71
Navy Supporting Member
How many miles is on the vehicle/sensors? IMO, any time after 100k miles, the maintenance on these sensors requires all 4 replacement, to help protect the catalytic converters.
It's not your sensor, the cat is dead; unless you have an exhaust leak on that side.
B
BG1988
I used M4 I was able to do a drive cycle, all drive monitors are complete in 9 miles, now including the infamous "GM Evap monitor "...
obvious it's an DFCO issue then a Cat issue.. since DFCO is 'off' in M4 as well as the AFM
according the the Diagnostics sheet HO2S2 Post o2 sensor(Sensor2 ) ≥101 mV for 2.50 seconds prior to a DFCO exit... that is an enable condition
if my second sensor is dropping to a random "DFCO event " while my Bank1sensor2 is not then must be an issue with the sensor it self i'm going to replace all 4 of them the suv has 109k on it...
B
BG1988
deceleration fuel cut off the PCM has an aggressive version of DFCO to save a few drops of fuel and a even more aggressive version of AFM.... remember it can accelerate in afm
B
BG1988
a broken cat would have been reviled when i did a drive cycle with DFCO off
as i would have gotten the P0430 again before the drive cycle completed
maybe it just needed the italian tune-up i was running the engine at 3500-4000rpm for several miles... Yes the engine was warmed up before doing that
We used to call those an "Arkansas Tune Up".
B
BG1988
I got the O2 sensor installed on the passenger side I gave up on the driver side for now i'll try on sunday for the driver side ...
Dh1280
