Rust on 2009 Yukon Denali XL
smiley91
Hello, I recently came across a pretty good price for a 2009 Yukon XL with 170k miles. What I have seen so far looks pretty good, except for the passenger side rockers and rear quarter panel. I am noticing a decent amount of rust, and wanted to get some feedback from you all on whether or not:
1) It looks manageable to you (either by basic primer sprays and some POR15),
2) If it would be worth an immediately inspection (which I would do regardless, just trying to get a feel for realistic scope of this issue.
Are there any glaring red flags besides the rust that you are seeing?
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
The quarter is rusted through and it is questionable if the rust on the rocker is just on the surface or coming from the inside out. The correct way to fix both is to cut the rust out and weld in new metal. I would pass.
However, what is the price?
B-train
What you see is just the tip of the iceberg. Below and inside will be much worse. I agree with above on a PASS. You'll never be able to actually FIX it and it will be a continuous, disappointing battle.
If it's cheap, then you could run it as is and part it out when done. Or use it as a donor vehicle to stuff that's still in decent shape.
S
smiley91
They are asking $10,900.
91RS
GA
Yikes. Double pass at that price. That will buy a rust-free one down here.
tungsten
I was looking at an 07 yukon xl same mileage slt
$5500,no visible rust in pics but I know its there somewhere.I dont know how much if any a Denali would be more.The all wheel drive thing would concern me at that mileage.
wjburken
Eastern Iowa
I would pass, especially for $10K+ and I’m not one to be afraid of rust, but only if I’m buying a beater truck for my kid. As has been mentioned already, you are only seeing 5-10% of what’s there.
B-train
Geez....at that price I would also hard pass as stated above.
I'm not sure how the whole importing process works for stuff from down here in the USA, but it might be worth a trip to get a clean one for less money.
Off-road Doberman
