Running board hardware question - HELP
Denali Z
i purchased some running boards for my 08 Denali, they came with the boards and brackets pre mounted but did not come with bolts and washers. I am in need of some help finding all the bolt sizes needed to install. Please help!!
fiatdale
Houstons Best
Houston
Couldnt tell you what thread the stock ones are but the bolts are 13mm head on the stocks.
Slow5.0
Missouri
There are 28 bolts, 10 10mm , 16 13mm and 2 13mm with big washer that goes up front. I could find dimensions and thread pitch this weeked
Btw 8 13mm bolts that bolts on the bottom, dont screw them straight up, they have to be angle out. You will see
Slow5.0
Missouri
Here are those bolts you gonna need
8 x M8-1.25 x 30mm with 24mm washer
10 x M6-1.00 x 17mm with 24mm washer
8 x M12- 1.50 stud with M6-1.00 inner threads (these may come w/running boards
2 x M8-1.25 x 50mm with 31.5mm washer
Make sure you get stainless steel or good grade bolts/washers because they will tend to rust
HeavyHoe03
