roof rack crossbar removal
NC_John
North Carolina
I hope this isn't a stupid question but after a quick look last night I couldn't figure it out. How do I remove the roof-rack crossbars on my 08 LT? On my 02 I just removed the rear trim cap and slid them both back and out/off. I tried that on the new one and found real quick it wasn't going to work.
Am I making this more complicated than it is or did GM decide to make it more complicated on the NNBS trucks?
Wakinvol
East TN
Same general concept. Remove the rear screws, pop off the plastic pieces, and slide the bars out the back. Then re-install the hardware and end pieces. Not too bad
NC_John
NC_John
North Carolina
I took out one of the screws from the rear in an attempt to do that but instead of the plastic coming off, it was trying to take EVERYTHING off. I could not see how to separate the plastic cover from the base assembly and sure as hell don't want to break it. The way the cover seems to wrap around, it doesn't look like it can be removed from the base with the rail in place. I may take another look this evening.
KMeloney
There's a tab on the plastic end piece that keeps it locked to the side rail. You'll have to undo that tab in order to slide the plastic end off. It's not the easiest thing to locate and do, but once you know that and look for it (and release it with a screwdriver), you'll be good to go.
NC_John
NC_John
North Carolina
I'm guessing its on the front of the rear assembly?
Thanks guys.
NC_John
NC_John
North Carolina
Got it! What I was missing was both screws had to be removed and the entire base unit taken off. Just the cover/trim comes off with the NBS. Thanks guys :Handshake:
And were you as pissed off as me that the factory saved $0.10 a truck by not putting a rubber gasket beneath the unit (like on the NBS) so it wouldn't scratch up the paint? What a bunch of morons.... You pay this much for a vehicle and this is what you get? No wonder the rest of my family drives BMW's.... I'm the only one slumming with chevys..
KMeloney
I hear you! But the Esky one, with it's rail-long rubber gasket, still etches the paint. If ANYTHING can get between the gasket and paint, it'll scratch. Oh well.
InTruckDesign
SW CT,
that's weird, both my '07 tahoe and my '11 burban have the rubber piece under the end caps.
KMeloney
Under the STOCK rack's end caps?? The stocker's caps are just cheep, thin, slightly flexible plastic. I can't really imagine any rubber between them and the paint. Mine certainly didn't have anything between the cap and paint. It was just the cap, itself, sitting on the roof.
glad2badad
Here I go resurrecting another older thread ... sorry. Not sure if it's better to post in an existing one that fits or create a new thread.
I'm looking to remove the crossbars on my 05 Tahoe and wonder if the process matches what's been posted here so far. Just remove the one screw and lift the cap? Here's a photo of what the rear cap looks like.
I'm a little nervous about removing that screw and then running into problems with an insert or something putting it back together.
Reason for doing all of this is the kayak racks I bought work "okay" on the OEM crossbars but not quite as snug as I'd like them ... so I'm going to install some 3rd party (Malone) bars. Here's the load I'm carrying sometimes now. :)
AdrienR
