Resetting or calibrating outside temp sensor
St. Louis
The outside temp sensor reads a bit higher than it actually is outside. I can understand a couple degree difference since it is located near the radiator, but sometimes mines off 5-6 degrees (reads 98/99 when it's actually 93 out).
I believe the Tech2 has the ability to reset this. How does this work, any other proceedures needing to be done to do this?
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
gooffeyguy
St. Louis
Nevermind, I found this "instant update" procedure on another forum
To perform an instant update of the Ambient Temperature Sensor, simultaneously press and hold the Recirculation button and A/C button on the HVAC control head.
You can also do an instant update with the scan tool
2001 Yukon SLT
gooffeyguy
St. Louis
Didn't know that thanks. Is that in Special Functions somewhere? Which module? HVAC?
Yes, I've seen it previously but don't remember where exactly. I remember seeing OST update.
This is all I found on another forum...
To perform an instant update of the Ambient Temperature Sensor, simultaneously press and hold the Recirculation button and A/C button on the HVAC control head. (Fig. 13) It is also possible to perform the instant update by using a scan tool in the special function mode and selecting instant OST update. Within a few seconds, the Driver Information Center should display the current temperature.
2001 Yukon SLT
wjburken
Eastern Iowa
My OAT gauge says its a lot hotter than it is. I put it off to having a black suv.
I’ve noticed that the temp on ours skyrockets when idling but will settle in once the vehicle is moving. Never compared with anything other than what banks have and it’s always been close enough for me.
We have two outside temperature sensors and on mine they are not always the same but only vary by a few degrees if memory serves. I think one is for the HVAC and the other for the ECM.
gooffeyguy
St. Louis
One is in the MAF sensor to get the intake air temp for the ECM
2001 Yukon SLT
gooffeyguy
St. Louis
More info I found on how the outside air temp sensor operates ...
The outside air temperature is displayed on the Driver Information Center, radio or rear view mirror in a number of GM vehicles. There may be some confusion about the operation of the display and how quickly it updates ambient temperature. Depending on several factors, the temperature may not be updated immediately and owners may feel that the display is inaccurate at times.
The ambient air temperature sensor is a variable resistor interfaced to the Body Control Module (BCM). The BCM provides the logic for reading the ambient air temperature sensor, filtering the data and transmitting the information via the serial data circuit to the outside temperature display. The outside air temperature algorithm uses three pieces of information: outside air temperature data, vehicle speed, and the time the engine was turned off.
When the engine is first started, the algorithm looks at how long the engine was off and if the outside temperature is lower than the last reading taken during the previous ignition cycle. From this information, it's determined if a new outside temperature reading should be taken.
If the engine was off long enough or the current outside air temperature is cooler than the stored value, a new outside temperature reading is taken and displayed. If the engine was not off long enough or the current outside air temperature is higher than the stored value from the previous ignition cycle, the last stored value of outside air temperature taken will be displayed.
The outside air temperature will continue to be updated every second as long as the outside air temperature is the same or cooler than the previous reading. Once the new outside air temperature reading exceeds the previous temperature and the vehicle is traveling less than 18 mph (29 km/h), the displayed outside air temperature will remain at its last value. Once the vehicle speed exceeds 18 mph, the displayed outside air temperature will be updated. If the speed drops below 18 mph, the outside air temperature will freeze at its last value.
The ambient temperature display may be slow to update the outside temperature at times or the A/C compressor may not operate due to low ambient temperature on some 2008-2012 Enclave; 2009-2012 Traverse; 2007-2010 OUTLOOK; 2007-2012 Acadia, Escalade, Escalade ESV, Escalade EXT, Avalanche, Silverado, Suburban, Tahoe, Sierra, Yukon, Yukon Denali, Yukon XL, and Yukon Denali XL models.
The outside air temperature display utilizes a very specific filtering routine of the Ambient Temperature Sensor signal so the display will update gradually without making large jumps in the reading. This is designed to eliminate the possibility of erratic readings under certain driving conditions.
The temperature display is always allowed to update quickly when the ambient temperature is getting colder while driving, but the display takes much longer to update when the temperature is getting warmer. This prevents false updates to the temperature display while driving in slow or stop-and-go traffic in hot weather.
The temperature display will always read the actual ambient temperature when the vehicle is started if the temperature has dropped since the last key cycle. It will not immediately update to the actual ambient temperature if it has gotten warmer since the last key cycle unless the ignition has been off for at least 2.5 hours.
2001 Yukon SLT
Kee Fuller
las vegas
Just tried this, didnt work for me. I got the dial ac controls if that makes a difference
An “instant update” isn’t the same as a calibration IMO. That seems like it would just look at what the sensor is currently seeing and display it immediately. If the sensor is reading incorrectly, it will still display the wrong temp.
olliec420
Having fan and a/c issues. Just realized the temp on the DIC was stuck at 64. Went up to 66 and then down one to 65 over a 40 minute drive with a lot of highway. It is more like 75 out. Has been working normally until recently. It seems like its moving but like another user said, not calibrated. Has any one any suggestions for calibration and not just an update?
Edit: replaced the ambient temp sensor and it worked well for a couple days and now back at 64 again, wtf?
rossida
