Replacing factory door speaker questions
Brizzle
Speakers going in a 04 tahoe 2wd 4.8L without onstar or bose
Looking at purchasing http://http://www.bestbuy.com/site/Polk+Audio+-+6-1/2%22+Coaxial+Loudspeakers+with+Poly-Mica+Cones+(Pair)/9985099.p?id=1218205765007&skuId=9985099
Best buy is telling me i need to use a step down transformer.
is it neccesary to run these speakers with the step down?
Does the step down matter if deck is factory or aftermarket?
Is step down installed on the postive line of speaker? if not how is it installed?
On a scale 1 to 10 how hard is it to replace front and rear speakers?
Considering installer has some mechnical and electrical common sense?
new to forum looking forward to modding my tahoe.
Thanks
Brock
blueflamed03
Oklahoma
just find some 2 ohm speakers. The Bose unit needs a 2 ohm load, where most door speakers are 4 ohm. Then no need for anything else.
B
Brizzle
That would be the easy way out. May do that if polk audio offers the speaker i want in a 2 ohm set up.
Can i hook up a 2 ohm reisistor parllel across the speaker?
If so what size wattage resistor?
chevy_man
Great Falls
He says he has a NON-bose system.
I installed a set of infinity 2-ohm 3-ways in my buddies 06 silvy with no problems (non-bose also). Put a identical pair in my denali with no problems either.
Best buy is just looking to get extra cash for the install. I've never heard of such a thing as a "step-down transformer" in the car audio business myself. I have however installed many transformers at work (electrician) and they're all step-down, or step-up depending on which side is your line/load. However it makes no sense to modify the voltage going to your speakers.
Cliffs: You're fine with the polks (although your link didn't work) because any 4-ohm speaker will work.
B
Brizzle
Thanks guys for the post
Just to make sure i understand right
is the non bose speakers 4 ohms?
Bose speakers 2 ohms?
blueflamed03
Oklahoma
ah, correct, read into it. Just grab some 4 ohm coax or components and rock...no step downs needed.
afpj
Just FYI: I used the following video to help with door panel removal:
http://www.youtube.com/watch?v=wozuQR9o0gY
I too have nonBose system with subwoofer. The stock front door speakers say 4 ohms and Made in Mexico. I went through Crutchfield because for 50 buks, got 2 replacement speakers, wire harness adapter, and ring adapter all included. I couldn't beat that at BestBuy or Fry's. Good luck
tom q
Modesto, CA
I have a bose system. Installed a sony 4 way speaker in front 4 ohms. Have no problems with it.
Replacing door speakers scale: 3... depends on you though. I think you remove 2 screws for the panel. Lift the panel up to unhook it from the door. remove the wire connectors and there you go.
BTW, do you guys kjnow where I can get a ring adapter for the speakers?
B
Brizzle
Thanks guys for all the post.
You tube video was sweet. Don't look bad at all taking panels off.
I will be sure to post pics of install.
Start off with componets in front and back.
Next month do the double din deck.
Following that with jl 500w amp and 10'' w7.
kchaga1978
