Removing rear trim panels.
992door
Greenville, NC
How do you take out all of the trim panels on the right under the window
rdhenderson
Bellingham, WA
Need to remove the small trim panels at the back and the locking pillar trim panel in the front then pull out the bottom of the panel. Once that is done you should be able to lift the panel up and remove it.
992door
992door
Greenville, NC
Do you know if there is enough room behind there to put a .65 cubic ft sub box behind it?
TigerEyz3
Slow and Steady
TN
Assuming you have rear AC, you'd have to remove the blower to accommodate a custom/fiberglassed box, but I don't see a problem fitting a box that size otherwise. I've read of someone on here running 12-15" subs (one on each side) without interfering with the cargo space (can still fit 48" drywall/plywood boards between the wheel wells).
moviewithnotitle
Jersey
You original post on this had some good info.
http://www.tahoeyukonforum.com/forum/showthread.php?t=32492
Another Thread about Subs...
http://www.tahoeyukonforum.com/forum/showthread.php?t=15287&page=2
I have my amps on that side behind the panel...
http://www.tahoeyukonforum.com/forum/showthread.php?t=16120
If you don't mind cutting a little sheet metal, I would expect that you can open up some room in the rear section and cut some metal away and take advantage of the extra space out to the exterior wall.
Or even get a new panel from a junkyard. Build the box how you like, then trim the panel however needed. then merge the two together. You could probably tuck it in there pretty good.
dizhai
