Recommended airbag setup to tow on 26s w a 2/4 drop
Renzo778
I want to make sure that I can still tow and not lose the auto ride once my Denali gets dropped. I'm certainly not trying to rub the rubber off the rear tires once a load is put on it. I've got the bell tech 5305 springs, end links, shock extenders and a spohn adj panhard bar. I'm trying to drop it and try to keep the ride as factory as possible (the auto ride is great). I'm riding on 305/30/26. Any and all suggestions are much appreciated. Thx
NORCAL SS
SUV SUSPENSION GURU
you will need
rear djm endlinks/my bumpstops (which i sell for 110 shipped)
you then cut the bracket off the frame in rear so you get more travel
Then you add the airlift 60742 helper bag kit inside the coils. Ive done many trucks same set up and will tow fine. My escalade had same set up before and towed my ctsv no problem.
Eickybobby5050
