Rear Locking Differential Rebuild Price
EddieC
Would $1600 be a reasonable "all in" price for on-vehicle rear oem locker differential rebuild on '08 Tahoe?
That includes new gears, bearings and posi, lube and all labor.
Oops, axle bearings and all seals included.
Geotrash
Dave
Richmond, VA
Would $1600 be a reasonable "all in" price for in-vehicle rear oem locker differential rebuild on '08 Tahoe?
Yep, sounds fair to me. I spent $1200 to have just new bearings and seals in my front diff on a 2002 suburban a few years ago.
EddieC
EddieC
Thanks guys. That was the all inclusive price if everything is replaced, but that remains to be determined.
I omitted axle bearings and all seals from the list, but they are included in the price.
RED TAHOE LS
Rossville, Georgia USA
Reputable NAPA facility just under $1100.00 less ring/pinion. Good luck to you, find a STABLE MECHANIC not a school kid working in a quick lube rat hole.
EddieC
EddieC
Didn't see new posi unit on your sheet.
Quote was from seasoned specialty shop that does just axle/spindle work. No complaints posted.
I am trying to weed out shops that don't routinely do it.
Sorry but I'm not a fan of NAPA since getting a muffler with welds worse than my first adult night school class in welding (and those were horrible). Most other NAPA parts I've had to get don't appear to be on par with GM oems and cost as much or more so I rarely head there.
if it's a eaton detroit there putting in there sounds about right.
jz57
2007 Tahoe Rear Differential Repair parts only expense, I did the job by my self in the Spring of 2021:
1) Differential Carrier Bearing & Race
Timken #: SET36 (Bearing & Race set), $12 from Rock Auto
QTY: 2 sets
2) Rear Wheel Bearing & Seal
Timken #: TRP59047 (Repair Bearing with Seal), $23 from Rock Auto
QTY: 2
3) Differential Carrier Shim Pack
Advance Auto Parts #: 1101, $7, 13-pcs pack
QTY: 1 pack
4) Gear Oil
Walmart SuperTech 75W-95 Gear Oil, $5.95/Qt
QTY: 2 Qts
5) Differential Carrier & Gear
Eaton 913A481, $485 from Amazon
QTY: 1
6) NAPA CRC Super White Grease as Gear Marking Compound Substitute
$4, 14-Oz can, much cheaper than yellow color Gear Marking Compound in the market
7) RTV Sealant
8) Harbor Freight Dial Indicator & Base $23
Total Cost Around: $565
EddieC
EddieC
JZ,
Good for you and thanks for taking the time to outline that.
Unfortunately I'm at the age of "the older I get the less I know". Thirty years ago I'd rip into anything. Now I've learned to let someone with experience earn their living and I don't pay twice after after messing up. If it was a preassembled "pumpkin", sure, but not in this case.
And I don't have a press or tools tools specific to the job and am at the age of reducing the collection rather than add to it.
EddieC
EddieC
Any opinions on Yukon Gear posi unit?
What does GM originally use for the G80 locker?
Geotrash
Dave
Richmond, VA
The G80 is an Eaton product. Have heard good things about the Yukon Gear unit. A few others here have installed them but I don't have any personal experience with it. I've owned three G80 units over the years, and thankfully have never had a problem with any of them, for a combined 400K miles.
wsteele
I agree, my G80 has been very reliable. There are better options for off road centric users but as a daily driver, normally unlocked unit, it is a good compromise.
I wouldn't consider an alternative that is normally locked and unlocks as the alternative mode, so if I was upgrading rear ends for more serious off road work, I would try and see if I could install an air locker or perhaps one of the newer eLSD options. I understand the new electronic limited slip units like come in the new AT4 Yukons are very sweet.
EddieC
EddieC
One rebuilder uses Yukon duragrip but I agree that the G80, the way we use it, has not be problematic, possibly until now. It does still lock, but something is amiss back there.
Cammed 2002_Yukon
