MarkD51
Hello all,
With some recent tinkering on my '97 Tahoe due to some new 22" wheels-tires, I was in the process of decranking my front end, when walking around and taking measurements at all 4 corners, discover a difference of rear height of more than 1".
Although my Hoe only has 39.8K miles on the vehicle, it is possible father time none the less has taken it's toll on the rear leaf springs? The driver's side is quite a bit lower than the passenger side, and suspect the cause is the additional weight of the gas tank as a cause of the droop over the years.
I have inspected both leafs, no cracking, and living here in NM, my underside is extremely clean for a '97 vehicle.
What's the solution? Even with Firestone Air Bags in the back, I'm finding it difficult to get same measurements at the rear, even with a 20 psi difference, still no cigar.
New Springs, swap Springs, what can be done to correct this?
Should I be worried?
