Rear coolant lines
CDNTAHOE
Edmonton,Alberta Canada
Sorry if this is in the wrong section but, It's - 15 degrees here in Alberta went out to start the tahoe and noticed coolant behind the rear passenger side tire .I looked and saw leakage coming from what I assume is a rear coolant line for the rear heat. Is there an easy fix and also is there coolant lines for sale at saw Rockauto for this? I do use the rear heat for the grandkids. Thanks 2002 tahoe z71.
JPeter
