Rear coilovers using Viking?
KidWgn
Certified Kid Hauler
St. Louis, MO
Anyone tried it yet, or am I about to guinea pig this?
AFP offers the front coilover, which I'll be installing regardless. I wanted to keep all 4 corners similar, so I figured I'd use Viking's in the rear, too. Upon browsing, it looks like you can get the shocks with a smooth body, or threaded for a coilover setup. The shocks can be mounted inverted, too.
Has anyone tried a coil-over-shock setup in the rear?
probably going to end up in a fab-your-own area running coil over's and a solid floating rear axle, I don't think you will find many if any off the shelf stuff, check with the desert racers
Dustin Jackson
I think the last I saw this topic there wasn't much of a benefit to fabricate the rear end to facilitate coil overs
EFD2024
